yank ss4000 and slower times?
I would make a few more passes and see if your times get better.
Going from a 2800 stall to a 4000 stall should keep you in the engine power band much longer. You should go at least .2 quicker in the ¼.
Are you sure about the DA numbers? I know my car will be ~.35 slower in the 1/4 with a DA of 1800 vs a DA of -200 and it will not 60 as well either.
John
By the way John, thanks for yoru response to my post about my new converter making my 2-3 shifts hit the limiter!
Bill
Bill
Simply explained DA or density altitude is a measure (in feet) of air pressure based on your track elevation, temperature, barometric pressure, and dew point or humidity. It is also part of an ET/MPH correction factor.
The lower the DA is the more horsepower your engine will make and the faster you will go because there is more oxygen in a given amount of air.
As and example:
Spring/Fall racing conditions
Track elevation = 185ft
Temperature (F) = 50
Altimeter Setting raw with no correction (barometer) = 30.25
Dew point (F) = 35
The DA would be –657ft, which is great air. With this DA my car will run 6.96 – 7.02 in the 1/8.
Summer racing conditions:
Temperature (F) = 85
Altimeter Setting raw with no correction (barometer) = 30.10
Dew point (F) = 65
The DA would be 1953ft, which is poor air. With this DA my car would run around 7.3x in the 1/8.
See link below for a DA calculator:
http://wahiduddin.net/calc/calc_da.htm
There is also a good article in the June Car Craft magazine, which does a good job of explaining density altitude.
John
