400 in an f-body
Old Apr 14, 2006 | 04:38 PM
Cbrakllr's Avatar
Default 400 in an f-body
Ok I have a couple of questions about putting a race prepped 400 in my 01 camaro. My first is I was looking at the stuff from speedinc.com and the speedo sensor, whuch one do you get? Also will I benefit besides the bigger converter factor will i gain time from the 400? My last question is what is a manual valve body? Is that where you have to shift through all 3 gears? Sorry for the question that have probably been asked and answered a thousand times. Thanks for the help in advance.
Old Apr 14, 2006 | 04:43 PM
z28convert's Avatar
reliabilty up to 500 hp and alot more if built
manually have to shift gears, yes.
Old Apr 14, 2006 | 04:57 PM
Cbrakllr's Avatar
It says it is built
Old Apr 15, 2006 | 12:29 AM
revtime's Avatar
I have a Rossler TH400 in my 94.
Now I don,t know about the LS1/OBD2 cars but Rossler installed a VSS from an early 90s 454 SS pickup in my 400. When I installed it I just plugged the VSS wires right into the speed sensor and it works fine.
I have a reverse manual valve body and its kinda wierd getting used to shifting it all the time but I am starting to dig it.
I highly reccomend Rossler or Neil Chance build you a transmission. I am very happy with my TH400.
The best part is I know I will never break it.
Old Apr 16, 2006 | 01:10 AM
Strahley's Avatar
The reverse manual valve body is fun as hell on the street. Even those of us who aren't fans of the "frum roll??" races, it's tough to find a dead spot with the manual valve at most speeds
