Because you guys asked. TCI Deep Pan Pics
I am thinking of adding a second cooler in series with the first or going with a truck pan.
I know about 8 years ago I got a deep pan for my Iroc and that sucker hung so low I sent it back... so I have been kinda up in the air about deep pans since then. I have also heard that the fluid sloshes around and foams up.
I don't think it would ever run below 100 on normal driving conditions given the fact it is taking some heat off the motor......
My cousin builds these trans so I will ask him tonight.
I with you on this...
Transmission fluid, on the other hand, is just lubricating internal parts, as well as flowing through the valve body to actually work. Way I see it, so long as the fluid is reasonably viscous, keep it as cool as you want.
Anyone that has a converter should (for the life of their tranny) use an aftermarket cooler for the transmission. The factory one inside the radiator will not cut it, especially in summer. If you have a transmission temp gauge, watch it when you go WOT from a stop to 60mph....you can actually see the needle move up. Under those circumstances, mine will jump about 20 degrees in a few seconds.
The best way to keep tranny temps down is keep the converter locked up as much as possible. It will cool the tranny very quickly. Also note, that when unlocked, the tranny temp will soar. I had a misfire issue recently (computer issue) and it kept the converter from locking. around town (unlocked) the temps would hit 210+. On the freeway unlocked it would be close to 220.
Here are my operating temps: (all temps are once the tranny is fully warmed up.....20+ min of driving)
-freeway, normal driving, lockup in 4th: 125-150 (cold night vs. hot afternoon)
-around town, normal driving, lockup in 3rd gear @ 30-35mph: 175-185
-freeway, aggressive driving, multiple gears: 160-200
-around town, aggressive driving: 190-220
It gets pretty hot over here in summer, and like to put my foot in it a lot. So I'll be running a 2nd tranny cooler in series with the first, in a few months. I have the B&M 28,000 i think.
