tranny cooler leaking....WTF
Old May 7, 2006 | 01:11 PM
jlashley2001ss's Avatar
Default tranny cooler leaking....WTF
I noticed the other day that on my driveway there is something leaking. From the area(right front it seems) the only thing it seems possible is oil from maybe catch can or tranny cooler lines or something. anybody had problems with this before? Im no mechanic so please bare with me on this. TIA
Old May 7, 2006 | 01:21 PM
BadCompany VP WS6's Avatar
Mine was doing that...it happened to be one of the lines where the clamps were. Just re-tighten them to make sure.
Old May 7, 2006 | 01:30 PM
ok thanks... i hope thats all it is.
2001NBMZ28's Avatar
The color/consistency of the fluid should tell you where to look. Is your cooler mounted "dope" style? Hose connections tight and dry? Could also be dexcool, positive battery post leaking (if original Delco)...
Old May 7, 2006 | 01:59 PM
yeah its the original delco battery. how do you mean dope style?
Old May 7, 2006 | 02:20 PM
2001NBMZ28's Avatar
Check that positive battery post, happened to a friend of mine under warranty - gave him a new one - leaked again 2 years later. Dope style cooler mounting is horizontally under the right front, just forward of the air dam.
Old May 7, 2006 | 02:34 PM
aight i might just have to check that
Old May 7, 2006 | 02:36 PM
are you sure that the positve battery post would leak like that?? any other comments on this?
Old May 7, 2006 | 03:15 PM
2001NBMZ28's Avatar
Happens all the time - does the spot look kinda green when dry? Easy to check, if it's the post leaking it'll make a mess.
Old May 7, 2006 | 03:17 PM
well its been raining so i cant tell wet it looks dark sorda
Old May 7, 2006 | 05:03 PM
2001NBMZ28's Avatar
If it's the post leaking you should be able to see it with a bright light directed at the terminal.
