Too Much Tranny Fluid?
Old May 9, 2006 | 04:24 PM
transamhate's Avatar
Default Too Much Tranny Fluid?
just a question....how would my trans am act if i had more fluid than needed.....at low speeds or idle at lights it will start to die and when i hit the pedal nothing happen....my rpms dont move..nothing....then after like 4 seconds it all just starts working again and i bark the tires......i wouldnt even call this lag....its just nothing at all happens and then it all starts working again.....ive been told too much fluid is bad....but never what it does and how the trans acts
Old May 9, 2006 | 05:18 PM
EDS01SS's Avatar
to much fluid will fry your clutches just as quick as not enough fluid.If there is to much fluid it will start to create air bubbles in the fluid and the clutches will no longer contact each other like they are supposed to which makes the transmission slip.
