Tranny issues
Old May 20, 2006 | 09:11 AM
PBA's Avatar
PBA
The Trans-Go separator plate is "supposed" to be harder, it is not, about the same. I use the Torlon (AOD, AODE) checkballs to keep from beating up the plate, and they work out very well here. Line pressure at WOT should not be anymore than 235 psi., in 1-2-3-4 position. If it is and you are using the vacuum modulator, then you will need to grind down the length of the modulator pin. Every .010 removed = apx. 1lb. in lower pressure at WOT. I hope this helps!
Old May 20, 2006 | 11:32 AM
Honda Hunter's Avatar
Thanks for the good info
