help on th350
Old May 13, 2006 | 01:21 PM
Trashed's Avatar
Default help on th350
hey guys im bying a car with a th350 and does all th350's come with manual valve bodies? i want to run a ratchet on it so what are some part nmbers so i can get it hooked up? thanks
Old May 13, 2006 | 02:24 PM
8a8mfh's Avatar
do all th350's come with manual valve bodies?
No th350's come with manual valve bodies, if you have one with a manual vb is has been put in there by an aftermarket source.
You don't need any part numbers to get it hooked up reguardless of what vb is in it, all you need is to find a shifter.
Old May 14, 2006 | 01:18 AM
Strahley's Avatar
B&M's universal ratchet shifter works great with the th350, it can be had for a fair price also. If you are buying a car with that trans, what does the current owner use for it to drive? Is it an actual "automatic" th350? Or did they specify it was a manual valve?
Also, for what it's worth, I use a 2 foot long shifter cable with mine. It originally used a 4 foot long cable, but even with heat shields it ended up melting
Old May 14, 2006 | 03:45 PM
Trashed's Avatar
so i dont need manual valve body to run the ratchet? its a street fighter if that helps any
Old May 15, 2006 | 01:32 AM
revtime's Avatar
No you don,t have to have a manual valve body. You can run any shifter you like with a fully automatic tranny.
Mounting the shifter will be your biggest headache.
Old May 15, 2006 | 07:29 PM
Trashed's Avatar
alright man thanks
