Installed Transgo - Now P0785 trouble code
Old May 20, 2006 | 02:05 PM
69MyWay's Avatar
Default Installed Transgo - Now P0785 trouble code
immediatly after installing the Transgo in my 4L60e with 2,800 TCI stall, I am getting DTC:
P0785 3-2 Shift Solenoid Circuit Electrical
This is a A4 in a 69 Camaro with a modified LS1.
I ran a search on the board and only found a listing for what P0785 is. I found on trucks it can often be a faulty ignition switch.
When the light is on the car tries to start in 3rd gear or so. I can manually shift with no problem. I can shut the car off or clear the code and the next time it won't come on and shifting is good.
Where should I start?
Old May 20, 2006 | 03:24 PM
69MyWay's Avatar
Nevermind...Just pulled the pan and found one of my solenoids was unplugged. I am guessing I didn't click it tight then knocked it off when I slid the filter in.
