Is my transmission bad?
Ok, don't know if this is exactly tuning or my transmission, or what exactly. Before i put the stall in and since i bought the car in april 05 it has went into this "mode" i call it where it shifts really hard, it only does this after a 3/4 to full throttle instance. It also doesnt do it every time. To help explain it, if i shifted anywhere above 2500 rpm, its an A4, out of first gear, it would bark the tires. Then i got a stall and it doesnt shift as hard anymore, or do it as much, however, I do not have shift points now, whenever it shifted perfectly and never hittin rev limiter before the stall. It started this the day after the stall was put in on first full throttle which leads me towards a tuning issue. One last thing, whenever i dynoed it without the stall we had to take it up to 4200 rpm before it wouldnt downshift on the dyno. Now that i have a cam kit in now, i would like some help whether on deciding to rebuild/buy my 4l60e or try tuning it first and setting shift points. Which way would you go, or what should i check to make sure it isnt a line or anything else just causing this. I will take any opinion or comment or just random ideas at what it might be. Thanks
