Problem w/ Putting it into Park
Old Jun 2, 2006 | 01:11 AM
Npak's Avatar
Default Problem w/ Putting it into Park
i cant get the tranny to go into park. i took the tranny pan off to drain the trans. and when under it i checked to see whats going on on the ratcheting thing that puts it in 1,2,d,od,n,r,p and i cant get the ratchet to go into p. the notch is on it. but something inside the transmission is stopping it. any ideas on what i forgot to release or do to keep it from doing that.
Old Jun 2, 2006 | 09:25 AM
FHAWKer's Avatar
I have no idea, never worked on trans before, but I installed a switch in the bottom of the ashtray, and the bottom part of the switch was blocking the selector from moving into park. I don't know if you did anything like that, but check under the ashtray and see if anything fell in there.
Old Jun 2, 2006 | 12:54 PM
Npak's Avatar
ok, that sounds like an idea. i did move the whole console out when i was installing the car. thanks for an idea.
Old Jun 3, 2006 | 03:00 AM
Npak's Avatar
the dumb *** who built the rebuild put the linkage inside the tranny on backwards. cause itll fit either way, but only goes into park the correct way. now having problems w/ getting the ******* tranny turning the driveshaft. wont move anything.
Old Jun 3, 2006 | 03:32 AM
daniel6718's Avatar
adjust the tranny cable...???
if it dont do anything is the bracket for the shift linkage on backwards?
