will this cross over?
will the 4L60e out of a 00 camaro work in a 01 suburban?
looks like the tailhousings are different, and the shifter stud looks shorter on the fbody unit.
any huge differences that would make this not work?
Originally Posted by 8a8mfh
The tailhousings are the same except the f-body has torque arm mount bosses. It will work, but you might as well just swap them. Same for the shift shaft it should swap out also.
