4l60e
Old Jun 22, 2006 | 08:01 PM
funkymonkeys409's Avatar
Default 4l60e
this may be a dumb question but i dont know. i was wondering if a 4l60e outta a C5 vett is the same or can be put in a 98 camaro?
Old Jun 22, 2006 | 08:08 PM
juicedls1's Avatar
yes it is the same tranny, good for all ls1 cars
Old Jun 22, 2006 | 10:58 PM
staringback05's Avatar
if ur changin it might as well bulk it up to
Old Jun 23, 2006 | 07:03 PM
good, thanks
Old Jun 23, 2006 | 07:47 PM
FLT's Avatar
FLT
Sorry to say guys that the vet case is unique to corvette's only. It has a seal in the rear of the case to seal the output shaft and doesn't use a tail housing. The trans splines directly into the rear differential which has a seal as well. If you take and put this trans into an f-body,truck,etc there wiil not be any lube for the drive shaft slip yoke to tail housing bushing.
