Stock Trans Line Pressure?????
Old Jun 28, 2006 | 04:19 PM
02WSSICK's Avatar
Default Stock Trans Line Pressure?????
i have a stock trans with a 3000 yank stall -- using hp tuners what line pressure should i set it at so that i can run it down the 1/4 mile and not have it hit the rev limiter with it shifts????? someone please help
Old Jun 29, 2006 | 09:47 PM
mtb989s's Avatar
I had my pressure at 95 and it hit the limiter from 2-3, but when I tested the tranny with a shaeffer shifter the line pressure was at 115 and it shifted. You might want to start at 100 and then go from there. Maybe that will help.
I'm going to try and set my line pressure to 115 and see if this solves my problem.
Old Jun 29, 2006 | 10:45 PM
Roarin_8's Avatar
Read this discussion first
https://ls1tech.com/forums/automatic-transmission/114376-line-pressure-discussion-when-too-much.html
