tranny slippage or what???
Old Jul 10, 2006 | 11:40 PM
01arroyo's Avatar
Default tranny slippage or what???
when the car is cold first gear seems fine when second gear kicks in rpms go up but car goes no where. when the car is hot first gear runs fine but second gear kicks in pretty hard. fluid levels seem fine and the car is stock. any imputs before i burn the car
Old Jul 11, 2006 | 11:10 AM
01arroyo's Avatar
anyone?
Old Jul 13, 2006 | 11:59 AM
SoCalZ28's Avatar
Ive Got 95k On My Clock, Im Having The Same Issue...
Old Jul 14, 2006 | 07:33 AM
LS1-Master's Avatar
I think it is the 2-4band that needs to be changed.
Old Jul 14, 2006 | 09:15 AM
Cody Brooks's Avatar
I believe that there is an issue with the 1-2 accumulator spring that causes that. trans-go shift kits include a new spring and designed to fix what they call a 1-2 bump of slide shift. i'd say that sounds like a hydraulic problem such as accumulator or a valve sticking.
Old Jul 14, 2006 | 09:19 AM
MeanWS6's Avatar
yup, bands are shot/glazed
Go TH400 for forget about your tranny problems
