4L60E extra part goes where? Help
Anyone know where this goes ? Thanks
I installed it just as you said and it slides in and out with the help of the spring. Thankyou.
There is another selenoid right beside it, in fact its the same part number. I removed this selenoid and put my finger in the hole - The Shift Valve is almost like stuck in the hole. I can feel the end of the Valve- but it is not springy like the other one. Should it move back and forth?
Could this be my shifting problem ?
