Is it possible to put dual tranny coolers?
Is it possible to put dual tranny coolers? If so will there be enough pressure inside the tranny? We have one cooler on our car but was wondering if it would make sense to put on a second.
Yes you can run two coolers. Just bypass the Radiator first,
Then connect the line leaving the Transmission to the 1st cooler
Then the exiting line from the first cooler to enter the 2nd cooler
Then the exiting line from the 2nd cooler back to the trans!! Bingo.
Seen it done alot. Some say (I once said this) that it's best to get one efficiant cooler with a fan but you cant argue with the success of the dual fan people. I'm thinking of adding another cooler with a fan as well. I was told a tranny cant be to cool.
