th400 is in!! why is there lag going to second gear??
Old Aug 6, 2006 | 05:11 PM
Mr_president's Avatar
Default th400 is in!! why is there lag going to second gear??
well when i go from first to second at WOT there is a weird lag that makes the car bumerang into 3rd gear does anyone know anything about this? thanks!
Old Aug 6, 2006 | 05:30 PM
Predator T/A's Avatar
sounds like a stacked shift is the governor sticking and is the vac modualtor adjusted right
Old Aug 6, 2006 | 09:26 PM
sr71's Avatar
he has a manual transbrake valvebody. it does not use a modulator or governor.
my car did the same thing first time out...when I put the brake in it, I checked the clutch pack clearences and they were a little loose. I tightened the clearences up and the problem went away for me. but it could be something different in your instance.
