Newbee question 4L60E v.s. TH400
Old Aug 8, 2006 | 05:21 PM
transaman98's Avatar
Default Newbee question 4L60E v.s. TH400
So I am deciding what tranny I want to run in my car. Obviously I already have a 4L60e, so I am trying to decide wether to beef up my current tranny or swap it out for a TH400. I was wondering if you guys could tell me what the pro's and cons are for each tranny and which one would be better for a street car that occasionally sees the track. Thanks.
Old Aug 8, 2006 | 06:07 PM
ChocoTaco369's Avatar
Tech Resident
you won't want a th400. it has no overdrive. if you drive over 50mph you're gonna be in some **** gas wise. no to mention, you'd lose like 50hp by getting a th400 because it's extremely parasitic and the 4L60E has MUCH better gearing. you'll lose a lot of speed with a th400. a th400, from what i've gathered, should only be used in 700+ horsepower strip cars. once you get into that power range, the parasitic loss won't matter and for the strip, you don't need overdrive.
if you're going to be doing a lot of street driving, a 4L60E or a 4L80E will be your best choice. the 4L80E has overdrive and just like a th400 can take 700hp all day every day if it's built properly. the con is it's very heavy and expensive.
if you're making under 500rwhp a 4L60E should suit you just fine. just make sure you get one from a good builder like rock-on or FLT. if you just rebuild your stocker with a few better parts it's not gonna hold. you're gonna need a full-on race built 4L60E (costs around 2 grand), but if it's built PROPERLY, it can take a beating so i've heard. just in stock form it's a junk trans.
Old Aug 8, 2006 | 08:09 PM
revtime's Avatar
Wow, have you ever had a TH400? Have you ever driven a car with gears and a TH400 with a decent stall?
Lose 50 HP? My car went faster with the TH400, no changes to the motor.........tell me how I lost 50 HP.
Better gearing? give me a break, the spread in a 60E is horrible compared to the TH400. The only good thing about it is the steep first gear, and that will actually cripple you without traction.
I will give you overdrive, on the hiway its a nice thing but I will take the high RPMs over rebuilding the tranny every 20 thousand miles (my expierance only).
If the car is a weekend toy then throw in the TH400, if its a daily driver then I would go with a built 60E.
Not trying to be a dick, but that was some straight up misinformation right there.
Old Aug 8, 2006 | 08:48 PM
LSWon00's Avatar
I have to agree with revtime above. I don't have a TH400 but its on the list of things when the 60E takes a crap. OD can be had through an aftermarket tailshaft if I'm not mistaken. Yeah the OD units aren't cheap but neither is a 60E or a 60E rebuild for that matter.
Old Aug 8, 2006 | 08:58 PM
SSilverSSurfer's Avatar
th400 way more bullet proof than the 4l60 if you plan on hitting the strip alot, downside no overdrive but whocares
Old Aug 9, 2006 | 08:16 PM
Tech Resident
he's using it on his STREET CAR that will see the strip. getting a TH400 is a BIG mistake. he says he will occassionally see the track. you're gonna ruin his daily driver to go to the track twice a year?
and again, i believe the 4L60E is geared lower.
i've heard of people losing around 50hp with a TH400 swap. but maybe that's an M6 conversion. either way, no one should argue you'll lose SOME hp. i just feel giving up OD is a very bad move for a street car. it's gonna kill your wallet and kill your engine.
Old Aug 9, 2006 | 08:50 PM
revtime's Avatar
Everyone is entitled to their opinion.
For me the TH400 was the single best thing I have ever done to the car.
And I said in my first post that if its a daily driver I would not put a TH400 in it.
Old Aug 10, 2006 | 01:16 AM
should i just put up a poll on the question?
Old Aug 10, 2006 | 10:34 AM
Zombie's Avatar
I run a th400 and put about 100-200 miles on my car a week. 2nd best mod I've done to the car (first was the turbo).
Chocotaco, just because a dyno reads lower after a transmission swap doesn't mean jack, you need to run the car at the track. Dyno's are not for racing, they are a tool for tuning, they also do not tell the whole story. I've seen graphs of a turbo mustang losing 200 rwhp on the dyno swapping from a T56 to a Th400, he ran a better ET with better MPH at the strip.
Transamman, if you are keeping the car fairly mild then a 4l60 is probably your best bet. Th400s become a good choice when you start to make a ton of power. You do have to give up overdrive, my answer to that was 2.75 gears though.
Old Aug 10, 2006 | 09:47 PM
11SECDWS6's Avatar
This is straight of of the Timeslip Database here on LS1tech (so you can verify):
RWHP...........Wght..........MPH...........ET..... .....Transmission
444..............3000..........132.3.......10.14.. ..........TH400
470..............3100..........134.96......9.96... ..........TH400
491..............3390..........129..........10.28. ...........TH400
413..............2950..........128.48......10.295. .........TH400
As you can see, these are no dyno queens, but damn sure git-r-done at the track.
Dyno queen = 4L60E
Track queen = Turbo 400/Turbo 350/Powerglide
Old Aug 10, 2006 | 10:22 PM
z28pat's Avatar
I am wondering the same thing transaman98 is wondering,
if you had to choose for a street/daily driven car that goes to the track 4 to 5 times a year, would you still choose the TH400?,
I know it's no question for a track car that the th400 is the one, but having no Overdrive sounds like a real pain.
pat
Old Aug 10, 2006 | 10:28 PM
11SECDWS6's Avatar
4L80E would be the way to go if you wanted to keep overdrive and be bullet proof also. But you'll have to pay $$$$$
Old Aug 11, 2006 | 01:13 AM
Joel_SS's Avatar
Dyno queen = 4L60E
While those are great numbers.. Look at the wieght they are all stripped.. I bet every one of them was trailored to the track.
But for a daily driver and occansion trip to the track a build 60e should be just fine.
Old Aug 11, 2006 | 11:06 AM
Zombie's Avatar
For under 500 HP I agree. If I could have had OD and lockup for cheap I would have, but it's hard to do things cheap when you make big power.
Old Aug 11, 2006 | 11:46 PM
11SECDWS6's Avatar
Not really, my ws6 has zero weight removed and weighs 3550 lbs. Thats only 550 lbs heavier than say, the first car that ran a 10.14 @ 3000 lbs. They say that 100 lbs = approximately .1 seconds off your et, so at stock weight, that would still make that car a 10 second car w/ just 444 rwhp.
I drove mine to the track tonight w/ TH400 and all. 35 miles one way. Temp got alittle hot, but not too bad. Drove all the way back w/ absolutely no problems.
Thats not what I understand. Just talking around w/ people at the track, I personally know a few people that went through 4L60E's left and right. Even built ones. I know of one person on this board who is well known that has gone through seven 4L60E's before he finally went to a 'glide.
