tranny broke , any ideas?
Old Aug 12, 2006 | 05:08 PM
93-vr4+transam's Avatar
Default tranny broke , any ideas?
Okay just happened lastnight, was running a 02' z06 hung by his door from 15-75mph. anyways on the second run, at the top of second around 6,000 Im a "auto". tranny started slipping. limped into gas station. here is what I found out, full of fluid. no burning smell. slips in all gears, will mover forward and rev. just slipping badly. didn't seem to lose any gears. Only thing I can think of is I put in a used 2800 stall 4 months ago.. should of went new. anyways can it be the stall went out all at once? or maybe the pump in the tranny went out? I hope the tranny isn't shot and maybe just the pump replaced. any ideas?
Just don't want to spend money on a stall if it dosent need it..
I do have a 400 turbo w/3800 stall I guess I can have it put in, how much trouble will it be to swap, I dont have the 4L60E, mine is a 93.. so pretty much a 700r4 in it now, will stock shifter work and other things hook up. I know I will prob. have to have my driveshaft modified, or a new one built...
just hate the idea of no overdrive, because I do a lot of street driving..
any ideas I would really appreciate it,,thanks.
Old Aug 12, 2006 | 06:05 PM
bjamick's Avatar
well does it slip only when you lay in the throttle hard or just giving it any gas? bc mine did the same thing but only when i layed into it. but my tranny needs to be rebuilt which might be your same problem the tranny rebuild kit from TCI only costs bout $350 for a pro racing kit
Old Aug 12, 2006 | 06:23 PM
it slips when giving it any gas..
Old Aug 12, 2006 | 06:50 PM
bjamick's Avatar
Well do you have the bottle on your car? and how many miles are on the car? and has the tranny ever been rebuilt?
Old Aug 12, 2006 | 07:33 PM
I don't run nos is that what your asking?
tranny was rebuilt less than 2 yrs. ago.
