What is your launch rpm with stall?
the one time I tried off idle launch at the track I spun.. but now that I think of it more that was the first run and I didn't heat the tires much on that run. other truns I heated them up more but stalled it up. hmmm... after reading this I want to go back now and heat'em up good and stomp it off idle again.
ive done it both ways and havent seen a diff in terms of track times. With the stall I usually hold it higher than idle, but no where near 2500rpm. I usually do it around 12-1600 just so i can control the spinning tires better as I can slowly roll onto it as I need the power through the hole. but like i said. U can go from idle and get the same results but you gotta learn to roll on the gas just right so that u dont sit there and spin.
Originally Posted by crazymofo1986
what do u mean by stalling it up. i always thought u just hit the gas.
iv been reading. i thought i had it. hit the gas aka flash the verter. wit ill go to the stall speed then launch. guess iv been missing sumthing......just have to wait till i have one
Originally Posted by Roarin_8
There's a trick though, if you flash the converter from idle, your tires may not be able to handle it and you'll spin bad. You have to find the middle ground.
Ive got a TCI 4400 in my car, it'll hold the brakes til about 2600 rpm, regardless if I'm on nittos or on mt et street radials, after that it starts pulling through the brakes.
Usually I launch the car around 2K rpm. Next time out I may play with it some and see if I have any better luck at 2500 rpm with the new h/c.
The convertor is going to flash higher than the brakes will hold. So launching the car at different rpms may not do much of anything. Ive noticed that it'll flash around 3600 -3800 rpm depending on how well it hooks.
