No Gears
Old Aug 22, 2006 | 06:29 PM
Red_Dragon's Avatar
Default No Gears
I have a 700R4 trans thought maybe you guys could help. i replaced the 3/4 clutch pack put it back together and mounted it and well it doesnt shift into any gear range when i shift it, it sounds like it does put some presure on the engine. I would guess that means the pump works? I'm not the best with autos so ya. any help would be awsome though before i start trying to trouble shoot. Oh I dont personally think its the torque converter either because that worked fine before i took the trans out and i didnt touch it, but again not sure.
Old Aug 22, 2006 | 07:01 PM
1999Z28's Avatar
did you hook the shift cable back up? just making sure,lol
i assume you pulled the valve body off. Are you 100% sure it went back together properly?
Old Aug 22, 2006 | 07:44 PM
Red_Dragon's Avatar
ya I hooked the cable back up I didnt touch the valve body though i just took the pan off to pull the selenoid and filter.
Old Aug 22, 2006 | 07:45 PM
ChocoTaco369's Avatar
Tech Resident
i'd double check your solenoids. sometimes they come unhooked.
Old Aug 23, 2006 | 05:55 PM
Red_Dragon's Avatar
Ya I went back a checked again its fine that the only plug in on the trans besides the spedo sensor. Right now I'm kinda looking at it like maybe some part of the linkage in the trans for when you shift got bumped or something. I really wish I had more knowledge on autos but this is the first one I have ever worked on. Anyone know exactly how the torque converter is engauged?
