yank ss3600
Old Aug 25, 2006 | 04:42 PM
Red 01SS's Avatar
Originally Posted by BlackHawk T/A
SS3600 + 3.23 gears here, car moves at 1400-1800rpm's but that is dependant on throttle.
You will be running between 1800-2500rpm's to get around town, unlocked. On the highway you will see around 1500rpm in 4th gear (locked) at about 50mph give or take. I have a video, let me see if I can find it.
Ya, what he said
Old Aug 25, 2006 | 04:49 PM
transamfreak01's Avatar
lol yeah guys im gettin some tires.... im not going to try to run this with street tires..... but other than that the converter should be fine
Old Aug 25, 2006 | 05:04 PM
Red 01SS's Avatar
Its not that bad on street tires. Mine is a H/C car with the SS3600 and as long as you are not a horrible driver you will be ok...
Old Aug 25, 2006 | 05:08 PM
well im only 17 so i havent been in this game for a long time but ill launch the car every once in a while but i get really bad wheel hop so ive learned to launch it at 1200 (stock converter) and give it half throttle... then count 1-1000 2-1000 and punch it and im fine then
Old Aug 25, 2006 | 05:18 PM
Roarin_8's Avatar
That depends on the type of clutch and your shift kit...mine certainly does not act like the stock one. Sometimes I wish it did
I don't have a shift kit, as far as clutch........um whatever this converter comes with.
Old Aug 25, 2006 | 05:35 PM
BlackHawk T/A's Avatar
I have the modified TransGo HD2 kit from FLT. With that and the Yank converter it hits hard and holds harder than stock. It adds some NVH.
Old Aug 25, 2006 | 05:36 PM
Roarin_8's Avatar
You also have a built trans, I'm still on the stocker. What's NVH?
Old Aug 25, 2006 | 05:40 PM
Noise, Vibration, Harshness. I'll have to see how much of that goes away when my mount is changed back to OEM, and my exhaust isn't dumped under the car anymore. Those contribute to that a bit
Old Aug 25, 2006 | 05:53 PM
Roarin_8's Avatar
I hear ya, the shop put in a poly trans mount since my stock one was shot. A little bit of vibration but not too bad.
