4L60 pump problems
Old Sep 9, 2006 | 02:44 AM
speedo's Avatar
Default 4L60 pump exploding have problems
Today I had major problems with my pump, my transmission builder said it looks like the pump sezied up and broke the pump slide, 10 vane rotor and front hub of the TCI torque converter.
He installed a trans-go no yo-yo pump kit, 10 vane rotor and slide, has anybody broke a pump with these parts in, or is there a better way to build the pump? My other question is does any company like FLT sell pumps that are built already?
Thanks for your time
Old Sep 9, 2006 | 08:49 AM
performabuilt's Avatar
LS1Tech Sponsor
The pump should be fine , These pumps are good durable units , when they fail its ussually due to some fault ot for instance debris from converter ect , I wouldnt worry about it to much ,
Performabuilt
Old Sep 9, 2006 | 09:58 AM
speedo's Avatar
Performabuilt
I should of mentioned in knocked a nice chunk out of the converter shaft where it incerts into the pump. So I am not sure if it was the coverter shaft being weak and letting go first or the pump locking up
