P0751 1-2 Shift Performance or Stuck Off
The solenoid clicks on and off (i can hear it tick) when doing a component test. Anyone run into this problem? Is this uncommon?
Tranny rebuilt 42k ago, fuddle 3400 with cooler installed 1.5k ago. Tranny fluid was clean before the converter install. Haven't check it since then.
I've cleared the code and it came back. It shuts itself off after awhile on it's own as well. What in the world does than insinuate?
You have to turn it off with HP tuners.
By clearing the code the pcm still thinks u have a stock stall and will think that the tc is slipping and therefore will throw the code, even though it is tuned. The only way to get rid of it is to completely turn it off.
