TC lockup issue
I installed a 3.42 rear and Fuddle 3000 stall converter in my wife's C5. I had W4MP do a tune. Now when she is crusing at a steady speed around 2000 rpm, the car will occasionaly feel like the TC unlocks for a second or two. I talked the the tuner and he saids this is normal (especially on Fuddles) and it needs a shift kit. I've got a SY3500 stall and it has never done this. Does anyone have any thoughts on what needs to be done??
https://ls1tech.com/forums/showthrea...5504748&conly=
Thanks for the info, now I have to convince Jessie to "try again"!!
Now, with that being said... I would take a hard look at the parts that were installed for mechanical problems. As stated above, this is a very easy thing to set in the tune (basically the one table).
I posted for some help and LS1 S replied.
The reason I posted in the 1st place was that I did call and speak with Jessie, and he said that there was notheing that could be done, except for buying a shift kit. With the thousands of TCs going in (including mine) I wanted to see if anyone else was experienceing it, and if not, what specfically could I ask Jessie to do to fix it.
LS1 S
I PM'd you
Thanks
