need help with tranny
Old Sep 12, 2006 | 10:45 PM
import slayer's Avatar
Default need help with tranny
I just installed my t-rex and my tranny started slipping will this help
HIGH PERFORMANCE OVERHAUL KIT C #4L6RK/HPC $349.00 All of the parts included in this kit are engineered to be installed in all transmissions behind engines producing up to 750 foot pounds of torque.This kit includes the general overhaul kit #24RK/G,5 radial grooved forward clutches and steels,2 radial grooved ovverrun clutches and steels, 8 red lined 3-4 racing clutches and thick steels(updated over the factory 6) ,5 lo reverse clutches and steels,5 reverse input clutches(updated over the factory 4),oversize 2/4 red racing band with welded anchors,updated 29 element input sprag, premium lo roller clutch, " THE BEAST" extreme duty sun shell ,complete bushing kit, and a complete thrust washer kit including front end play selective washers.
any comments will help a lot, thanks
Old Sep 12, 2006 | 11:24 PM
performabuilt's Avatar
LS1Tech Sponsor
well it sounds ok , but please bear in mind if you havent done it before rebuilding a transmission can be a very involved thing , If you havent done it i would seriously consider other options
performabuilt
Old Sep 13, 2006 | 11:11 AM
like what ?
Old Sep 13, 2006 | 12:14 PM
jpat1023's Avatar
a new transmission...or have a shop rebuild it for you...although, both are going to be pretty expensive, so if you think you can do it yourself, go for it!
Old Sep 13, 2006 | 12:31 PM
LS1Tech Sponsor
Agreed it is expensive to have a shop do it or to purchase one already built , but it is more expensive to build it your self several times while learning . I remember those days many years ago when i was like 16 and it was no fun , though on the other hand it did actually set the course of my future ,
