electrical problem with trans.
Old Sep 16, 2006 | 05:30 AM
LS12GO's Avatar
Default electrical problem with trans.
installed a 2700stall converter. now it goes into some mode in the computer won't come out of 2nd gear, until i clear the code then it works till next time it throws the code again po757. any answers will be great. plus it keeps showing gen.l code.
Old Sep 16, 2006 | 06:32 AM
FLT's Avatar
FLT
Sometimes after tc install this happens. You might have to have the code deleated and then have the test removed from your computer. What year is your car?
Old Sep 16, 2006 | 06:56 PM
LS12GO's Avatar
2002 L/T 12 bolt373 did'nt do it till trans went out had it rebuilt brand new converter had to have cut open and rebuilt then all the s*** started thanks for any imput
Old Sep 16, 2006 | 08:02 PM
FLT's Avatar
FLT
Usually this code is found when a tc with a stall of 3200 or higher. Like I said that you might need to clear this code and then have the test for this code deleated. Did this start after the tc was installed? You will need to see a tuner to fix your problem and have him do as I said. I believe this will fix your problem. Good luck, Vince.
Old Sep 17, 2006 | 04:43 AM
LS12GO's Avatar
thanks i am seeing a guy today about it at the track. again thanks, will let you know.
