3/4 clutch pack clearance specs?
Old Sep 20, 2006 | 10:46 PM
1999Z28's Avatar
Default 3/4 clutch pack clearance specs?
I keep seeing different answers. This is with the 8 clutches.
TCI says .050-.065
but i've seen .0.25-.035 as some answers on here.
GM says travel should be (0.083-0.035 in).
Old Sep 20, 2006 | 10:51 PM
SDB's Avatar
SDB
I have heard .035 so that there is less play and less chance of snapping the ears off the input drum...
Old Sep 22, 2006 | 05:24 AM
PBA's Avatar
PBA
If you are using the Corvette (LS1) servo, and adjust the 2-4 band clearance at a minimum, & no Trans-Go shift kit, then .045" - .055" should work. If you are using the Trans-Go shift kit, then .025" - .035" should work. If you have the transmission apart, change the 5 finger apply piston from a #7 or no number, to a #4. This will lessen the chances of a 2-3 WOT shift flare.
