lightweight flywheel in autmoatic??
Old Sep 23, 2006 | 08:38 PM
Formula_Power's Avatar
Default lightweight flywheel in autmoatic??
does anyone make a lightwieghtfly wheel for auto ls1 cars......would if be worth it??
thanks
Dustin
Old Sep 23, 2006 | 08:54 PM
2002 SS #476's Avatar
Automatic transmissions do not have flywheels. They have light weight flexplates. The fluid in the torque converter is heavy enough to dampen engine vibrations.
Old Sep 23, 2006 | 09:15 PM
so do you think i light wieght one is worth it?
Old Sep 23, 2006 | 09:22 PM
texinteg's Avatar
They are already light. And it doesnt matter cause you have a an auto.
Old Sep 23, 2006 | 09:23 PM
hpjunky98's Avatar
...no
Old Sep 23, 2006 | 09:30 PM
Flexplates are really only there for the pinion gear on the starter, axial movement, and a mounting plate for the torque converter. Flexplates fell like they only weigh a pound, there really light. No need to upgrade.
Old Sep 23, 2006 | 09:46 PM
BlackHawk T/A's Avatar
To add to that, many aftermarket flexplates are actually beefier and weigh a little more than the stocker, for strength.
