4l60e tranny cooler
When mounting the cooler, I am going to bypass the Radiator cooler and hook it up directly to the B&M.
Should I mont it hrizontal or vertical. I see many people putting it horizontal across the opening where air flows to the condenser. Correct me if I am wrong but that is "dope Style" correct?? The only problem I see with that is that it seems as if the air would be hitting the top of the cooler and going around it, but not through it. I was thinking about mounting it vertically instead.
Does anyone know which way will cool better based on actual trans temps?
Also on a side note. If I got a Transgo shift kit, billet servo, B&M 24k cooler and Raybestos Z-pack 3-4 clutches, is there anything else I can do to make SURE my 4l60e will last more than 1k MILES? I am getting sick and tired of fooling with it. ANY..I repeat A N Y suggestions of how to build this stronger to keep my 3-4 from going out PLEASE PLEASE PLEASE let me know. Obviously the words of a desperate man.
Thank you for any and all of your help.
theres a little more info in that thread you can read up on
