changing tranny fluid bad?
Old Dec 13, 2006 | 02:16 PM
ricardo colon's Avatar
Originally Posted by mullenh
shop owner here too. if you change it (and you should) get it flushed and treated with a cleaner, getting a trans service is not the same so do not confuse the two. it is probably not to late to save that one. you can check the fluid on a white towel and see how much debris is in it and check the color of the fluid. eventualy that fluid will loose all of its lubricating ability.
ever use sea foam trans tune
Old Dec 13, 2006 | 08:50 PM
mullenh's Avatar
no i have not
