Trans problem?
Old Oct 8, 2006 | 01:22 AM
sping012's Avatar
Default Trans problem?
This problem seems to happen after i hit 2nd gear. Whats happening is, when i go WOT from 2nd when it changes gear, theres a loud slam or pop sound? What could this be?
Old Oct 8, 2006 | 02:32 AM
performabuilt's Avatar
LS1Tech Sponsor
Check your mount and torsion bar under the car at tail housing area
www.performabuilt.com
Old Oct 8, 2006 | 02:59 AM
sping012's Avatar
Few questions on this, since i was thinking the mounts, but im not that machanicly inclined!
Can you see the mounts without taking off the trans support?
If you can see the mounts, should i be able to visually see the flaws while on the car?
Pretty much ditto on the torsion bar.
Thanks for helping!
Old Oct 9, 2006 | 05:32 PM
sping012's Avatar
Well it seems like the mount is ok. The car seems to stick during gear changing, no matter the speed. (mostly in 2nd and 3rd) It will get to the the next gear, but the cars trans seems to get stuck, and then it surges to the next gear?
Old Oct 14, 2006 | 02:15 PM
97turbotransam's Avatar
spring012 this is the guy with the sts kit for sale i tried to send you a reply but it said you had to delete some of them jus write me back, thanks
