C5 shifter in a '99 TA?
Old Oct 8, 2006 | 01:14 PM
howierd42's Avatar
Default C5 shifter in a '99 TA?
I am not sure if this is in the right section (I'm sure it will be moved if it isn't) but does anyone know if a shifter from a C5 Corvette will fit in a 1999 Trans Am? Both are automatics.
I hate the look and feel of the stock TA shifter and like the boot and **** on the 'Vettes so I was thinking of swapping if it can be done.
Anyone?
Old Oct 8, 2006 | 02:15 PM
The Guz's Avatar
I have been wondering the same thing.
Old Oct 10, 2006 | 01:36 AM
howierd42's Avatar
Bump ttt...
Old Oct 10, 2006 | 02:51 AM
hmm.....'s Avatar
i know that you can swap the camaro shifter in, a little of a PITA but worth it to some guys...
Old Oct 10, 2006 | 11:04 AM
12secSS's Avatar
No! Both shifter assy are not interchangeable. The F-Body shifter assy sit on a "frame", where as the C5 shifter assy sits below the floor pans and has a different mechanism to actuate the transmission.
The ***** may be interchaneable though.
Old Oct 10, 2006 | 02:52 PM
onebadblackz's Avatar
just put one of those in..... thats my 95 Z28
Old Oct 11, 2006 | 01:58 PM
jorgez28's Avatar
Can't you switch out the **** from a camaro to your bird
Old Oct 11, 2006 | 10:42 PM
howierd42's Avatar
Yes, but you still have a huge button on the top.
