Need tech help 4l60e BINDS????
The car is a 2000 ss with h/c and boltons 48k miles.
It has a vigilante 3200 stall.
The trans was rebuilt about 6,000 miles ago, but had the same problem with the old trans. did the same thing.
The problem he is having is under partial throttle it will bind when it is supposed to shift into 2nd. It doesn't happen every time and only happen when the tranny is up to running temp.
It feels like its trying to hold 2 gears at once???? I think it is a valve body problem where fluid is leaking past a valve that is supposed to be closed but is letting pressure bleed off to another passage.
He swears it is a computer problem (but there are no codes).
We have also been told it was the tune, had it retuned, didn't fix anything.
Was told it might be the stall but it only has about 15k on it and it seem fine to me.
We have taken it to a few transmissions shop but they can't seem to figure it out. (some won't even work on it)
If anybody has any idea on what it might be post it up.
He is about ready to torch the car because he has been dicking around trying to fix it for over a year and has cost him more money than I want to think about.
Thanks for any help.
Another possibily is cetrifical apply of the 3-4 clucth if the bind feels like its happening at high rpm in 2nd gear ,This is why the extra release springs were added to these units with the later model high rev engines , higher than 5000 rpm ,
performabuilt
@ WOT theres no problem.
If it starts to bind you have to let off, but if you go WOT when it starts to bind, it will bind for a few seconds, then make a loud POP noise(like something broke or released) then it will act normal for awhile.
So the 2-3 shift isn't the problem. I think its weird he has had the same problem with 2 trannys.(this problem is why the first on was rebuilt)
www.performabuilt.com
Is this a common problem? to have to seprate trannies do the same thing?
Would it be intermittent problem?
performabuilt
