does this sound right?
Old Oct 11, 2006 | 09:32 AM
TXZ28LS1's Avatar
Default does this sound right?
i just called a local tranny shop, just to see how much it cost to get a tranny flush and stuff like that. he said its $104. he says what they do is, drain out old fluid, and have a machine flush it out with some stuff, that removes 99% of the filth or whatever.. i asked bout replacing the filter, and he said its not necessary if there is some sort of leak or something like that. does this sound about right as far as price, and the right way to do a tranny flush?
Old Oct 11, 2006 | 10:00 AM
JDJP's Avatar
sounds cheap. but what kind of scares me, is the video of jiffy lube, they say they will use the machine to do a flush, but never even hook it up. Go some where you know is a good shop....
https://ls1tech.com/forums/showthrea...ght=jiffy+lube
Old Oct 11, 2006 | 10:20 AM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
it cost's alot less when they pull the plug and just drain whatever is in the pan. that guy you spoke to said he will push the rest of the fluid (more than 50% of what the tranny holds) out as well.
just to put the fluid back in the tranny is expensive enough when you flush all of it out.
Old Oct 11, 2006 | 10:45 AM
TXZ28LS1's Avatar
its one of the only tranny shops ive seen around san antonio. but as far as the maintenance process goes, does it sound about correct? i wouldnt mind paying 100 bucks to keep my tranny going, than blowing 2 grand.
Old Oct 11, 2006 | 11:37 AM
performabuilt's Avatar
LS1Tech Sponsor
Well that is inexpensive but Personally I would have the filter changed to ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 11, 2006 | 12:00 PM
01WS6er's Avatar
That price seems reasonable since places charge 99.99 around here to perform teh tranny flush. I would change teh filter to so I wuold have piece of mind
Old Oct 11, 2006 | 04:46 PM
TXZ28LS1's Avatar
yeah i mentioned bout changing the filter. but he said it wasnt necessary unless there was some leak in the gasket or some thing i couldnt remember.
Old Oct 11, 2006 | 04:57 PM
jmm98LS1's Avatar
Change the filter, that guy's an idiot. "I'm not gonna change da filter till the bitch starts leakin." Sounds like good logic.
Old Oct 11, 2006 | 06:13 PM
FLT's Avatar
FLT
When you do a flush like that the filter needs to be replaced. What most good shops will do is flush it first and then change the filter. IMO the right way to do it.Vince
Old Oct 11, 2006 | 07:03 PM
BigDaddyBry's Avatar
How many miles do you have on it? Depending on the miles, a flush on a 4l60e is a bad idea.
Old Oct 12, 2006 | 05:25 AM
TXZ28LS1's Avatar
i only got 35k miles on a 2002. ive heard some people say dont even flush yur tranny if nothing is wrong. so i dunno? any more input?
Old Oct 12, 2006 | 11:45 AM
ss4chad's Avatar
How can putting new fluid in your tranny be a bad thing? If you watch them do the work from start to finish you will come away knowing it was done. Flushing through the machine runs new fluid into the converter as well, just dropping the pan doesnt! Have them do the flush but before you go, open the hood and get familiar with the car, know where the lines that go from the tranny to the cooler are at so you know what should be taken off when they do the flush. There's nothing wrong with having someone work on your car if you dont have the time or resources, just keep an eye on whoever is doing it. Walk out into the shop and shoot the **** with the guys doing it, let them know your watching so they dont screw you!
Old Oct 13, 2006 | 11:46 AM
No one said changing the fluid was bad.
Old Oct 13, 2006 | 01:16 PM
joecar's Avatar
If you have time to DIY (and you don't mind DIY)...
https://ls1tech.com/forums/showpost....1&postcount=10
Old Oct 13, 2006 | 03:14 PM
TXZ28LS1's Avatar
so i called another automotive shop. they seem like a damn good organized shop. they charge $150 bucks for the tranny flush. they too said, they dont suggest changing the filter also ...
Old Oct 13, 2006 | 03:27 PM
01WS6er's Avatar
The reason most places don't change the filter because that involves dropping the pan and getting a little messy. They charge you 150.00 or so and hook a machine to your cooler line, press a few buttons and let the machine do the work. I done several of those.
I have complete flushed my tranny in my old 95 silverado at 175,00 before and had no trouble, but I had always kept the fluid changed. It finally wore the 1st cluch pack out at aroun 220,000 or so. I still change my fluid in my 94 gmc (4l60e) and it has 130,000 on it with no problems. Just my .02
Old Oct 13, 2006 | 03:42 PM
monicaz28's Avatar
That sounds like a pretty reasonable price really. I would get the filter changed, I would love to hear their explanation of why it shouldn't be.
Old Oct 13, 2006 | 04:21 PM
jmm98LS1's Avatar
Because they're lazy and don't want to get dirty dropping the pan.
Old Oct 13, 2006 | 05:56 PM
TXZ28LS1's Avatar
well, i looked at the service manual. and it says dont change tranny fluid or so when it hits like 50k miles. i think it does mention bout changing the filter. ill call one of the GM shops around here. i actually got my car at carmax. and ill see what they say..
