Shaking when in fourth,please help!!
Old Oct 11, 2006 | 08:12 PM
SPRAYED 01's Avatar
Default Shaking when in fourth,please help!!
This just started a couple days ago. If i take off from a stop at a steady 1/8-1/4 throttle when it shifts into 4th it chatters and shakes the car. Then it goes away after about 3 seconds. Any ideas,no other problems, every thing else works perfect. I was at the track saturday and accidently shifted into 4th on the spray once.
Old Oct 11, 2006 | 08:21 PM
performabuilt's Avatar
LS1Tech Sponsor
Best guess would be some converter clutch chatter ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 11, 2006 | 08:23 PM
SPRAYED 01's Avatar
How serious would that be. It doesnt really both me that much but at the same time i dont want to damage anything else. Would it be an actually converter problem or some kind of weird tuning issue???
Old Oct 11, 2006 | 08:33 PM
LS1Tech Sponsor
well tuning might hide the problem but more than likley the converter clutch has burned , Eventually it will fail if this is true ,
__________________
Call 888-744-6542
Old Oct 11, 2006 | 08:35 PM
FLT's Avatar
FLT
Tcc problem or a check ball thats stuck in the seperator plate would be my guess.
