Not your typical (lock-up) question
What I have: Rebuilt 4L60E trans w/ Yank PE4200.
My problem is when I go to or from work I go down a very large hill then go back up one. When I hit my brakes for it, the converter unlocks as normal. But, when going back up the hill it does NOT lock up again. I could drive about a few miles and then it would lock up again on its own. The converter locks up just fine when it does lock. So I don't think it's a converter problem. And the tune is fine, there are no misfires and the temp was adjusted again for the cooler weather.
Now here's twist. When it doesn't lock up I found out I can pop/stab the brakes real quick and it locks up just like it's supposed too. It locks perfect! Sometimes I can do it once and sometimes it take 3-4 trys. But it always locks up after popping/stabbing the brakes real quick
Another detail which may not have to do with anything is the "brake" light on the dash. It does not come on at all right after I swapped the rear end. It use to work but it doesn't anymore. Not sure why??? I also took the ABS/ASR off and disconnected the harness completely in the rear of the car. Those lights are on of course. This may just be a fluke and everything is failing at once but I'm just not so sure of it. That's why I'm including this in case it's part of the lock up problem.
This is the first lockup problem I've ever had. Like I said the tune is fine and there are no misfires at all. Has anyone had a similar problem or know why it's not acting right. Any help would be greatly appreciated.
hope this helps
I crawled under the dash and found the clip that holds the brake light switch in the bracket was a little worn out. The switch would sit sideways in the bracket when I was not hitting the brakes. It didn't take much to activate the switch. This caused the converter to not lock up because it probably thought I was hitting the brakes when I really wasn't. When I would pop the brakes it would make the switch sit straight and lock up perfect.
So I adjusted the the clip so it would sit in the bracket the correct way. And guess what! Works like a charm!
Thanks everyone for your input!!! Just think, I was about to start swapping solenoids. Glad I asked first!
