4L60E Slipping Problem, 3-4 Clutch Pack?
I am not a tranny person so I have a question I hope someone can help me with.
My car will not shift from 2-3rd at WOT (bangs the rev limiter forever). And when my car is on the freeway about 70 mph and I floor it it feels as if the trans is slipping. So, can both of these be caused by bad 3-4 clutch packs?
Can someone please explain what the 3-4 clutch packs do? What shifts are they responsible for? I would have figured since they are 3-4 clutch packs they controlled the 3-4 shifts. I know that is not the case since I have learned that the 3-4 clutch packs contorl the 2-3 shifts too.
So, what are the 3-4 clutch packs responsible for? Is it possible with bad ones to have it affect how the car jumps from a 70 mph roll when floored? Lastly, is it common for the 3-4 clutch packs to go out with as little as 25,000 miles?
The car has a 3600 Fuddle converter with a 2.3 STR.
Thanks,
Bill
most likley if its sjipping only in 3rd and fourth that would be the cause 3-4 clutch pack failure , And if something wrong presure wise they can fail in just very short few miles
