need help figuring out stall problem
Old Nov 9, 2006 | 09:19 PM
02BeaugusWS6's Avatar
Default need help figuring out stall problem
ok this might be a dumb question but i would appreciate it if someone could help me with it...to make it short i have an 86 camaro with a 355 and a TH350 tranny..the tranny has a shiftkit and what they told me when i bought it was a 6500 stall converter...the engine is a 355 with full boltons...yet i've never ran faster than a 16 sec. 1/4....i don't know much about stall converters but my guess is that it's wayyy too big and thats what is slowing me down...i think the car should at least run mid 12's and probably faster than that...so could someone tell me if that's the problem?
Old Nov 9, 2006 | 09:27 PM
performabuilt's Avatar
LS1Tech Sponsor
I would say a 6500 stall with and lt-1 engine is way high unless the engines been built to turn and awfully lot of rpms well in excess of 6500 rpm which is generally as much as a stock bottom end lt-1 can handle forlong. I cant say its all your problem but I would suggest you bring that stall down to the 3000 to 4000 range and Hopefully you have some gears in the 355 to 410 range ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 9, 2006 | 09:34 PM
i forgot to mention the gears, when i bought it they said it has 4.56 gears which i can believe cause i've never been able to push it much higher than 125-130 mph///the motor is out of a 78 z-28 too if that makes a diff.
Old Nov 9, 2006 | 10:11 PM
LS1Tech Sponsor
I would still have to say thats to much stall and helluva gear for and lt-1
__________________
Call 888-744-6542
Old Nov 9, 2006 | 10:16 PM
Razor_Blade's Avatar
They didn't make LT1's in 1978.
Old Nov 9, 2006 | 10:24 PM
LS1Tech Sponsor
I ment lt-1 style( early small block chevy) you know before the ls-1 lol
__________________
Call 888-744-6542
Old Nov 10, 2006 | 07:39 AM
thanks a lot for the help, i'm gonna switch it out for a smaller one and see if it gets me where i think it should be
