need convertor size help please
Old Nov 11, 2006 | 09:18 PM
WHITE DEVIL's Avatar
Default need convertor size help please
i have a 422 iron block that should make around 900-1000hp to the tires on the spray(400 shot) it is controlled progressively i am running a 3:73 in my 12 bolt on a true 28" tire i am running a th400 FMRVB off of a brake and 2 step, car weighs 3200lbs raceweight. i was wondering what type/ stall size was being run by similar setups and what would benefit me the best. any help would be greatly appreciated
thanks
jeff
Old Nov 12, 2006 | 05:54 PM
mullenh's Avatar
Thumbs up 67 tempest
Man you need to call Yank or TCI and they will want your complete setup. Good luck on getting a lot any reliable information here (LS 1 site) unless someone stumbles on your post. But the best method it to call converter people. I hear very good things about the help at 'Yank'.
Old Nov 13, 2006 | 02:09 PM
mrdragster1970's Avatar
6 & 8 Second Club
I always say the biggest you can get the stall needed from. Less big end slip. I have always used an 8" on my slow car. 8.50 1/4 mile, 1050 HP, 3200lbs.
To be honest, I have already decided to go with a 9 or 9 1/2 inch when I put it back together again. I use Coan, I have some TCI's also, but they were all redone by Coan. My fast car uses a 10", but that is probably too big for only 1000 HP.
Good luck where ever you go, dialing in a converter can be a pain in the ***.
Old Nov 13, 2006 | 02:38 PM
Yank's Avatar
Give us a call at 775 826 9955 and lets talk about your combo
Mike or Dave
