is it a big problem ?
Old Nov 14, 2006 | 08:17 PM
torlak_t's Avatar
Default is it a big problem ?
my problem with my 98 ss is, when i bring my car to 4000 or 5000rpm on P or N, it suddenly steps 10-20 cm forward altough it is still on P or N. is this the problem with transmission? i replaced the transmission kit 2 months ago as 3rd gear was broken. that stupid man couldnt put the parts in together well i think. comments pls.
thanks
Old Nov 14, 2006 | 09:37 PM
GOaT Cheese's Avatar
thanks
That is pretty normal. I have noticed that on lots of cars, don't really know what causes it other than clutch drag in the forward input drum. I wouldn't worry about it too much.
Old Nov 14, 2006 | 10:06 PM
performabuilt's Avatar
LS1Tech Sponsor
Its nothing to be concerned about
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 15, 2006 | 04:48 AM
torlak_t's Avatar
but i didnt have this prolem before replacing my transmission kit. do i have th 350 on my car?
Old Nov 16, 2006 | 01:41 PM
LS1Tech Sponsor
No you dont have a th350 unless you or someone else out it there you have a 4l60e.
but the slight pull forward is common to some exstent it may just be some drag on tight clutch sets or if its only happening really high and the aux springs were left out of the 3-4 clutch pack it could be the 3-4 clutch appling centrifically ,At anyrate I just wouldnt set and rev it that high in neutral or park its probably not a problem
__________________
Call 888-744-6542
