Good RPM to launch at with my setup?
Old Nov 16, 2006 | 11:42 PM
kaos_'s Avatar
Default Good RPM to launch at with my setup?
Please check my sig. Any ideas on what RPM i should be launching at, assuming i've got tires for the track? I want to get the best hook I can on launch with the least amount of spinning. Is there a definite rpm that will hook or does it vary based on other factors?
Old Nov 17, 2006 | 10:09 AM
bjamick's Avatar
stall it up as high as you can before the tires start spinning!! If you have a cam then you need to stall it up close to where the power band starts..
