A4 Problem
Old Nov 22, 2006 | 10:07 PM
performabuilt's Avatar
LS1Tech Sponsor
well as vince to said it generally better to change both but I dont really think you have a solenoid problem , I think you have valve body or presure manifold sensor problem ,
The code you mentioned sets when the presure manifold sensor doe not get the hydraulic signal expected from the solenoid , The other possibility is the presure manifold sensor is bad and just not sending the right signal , This type stuff is anoying to diagnose sometimes in a shop , typically you replace all the electrical possibilites first try , Manifold sensor,solenoids in a single operation , but realizing cost is a concern i can under stand one thing at a time .
Next I would do two things , I would pull the pan and replace the manifold sensor but while I was in here i would also remove that solenoid again and use a small screw driver to stroke the valve behind it and mak sure it will move ,
Im sorry your having a problem but I will be here if you have any questions all weekend
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 23, 2006 | 10:38 AM
2ThouZ28's Avatar
well, here's the deal. im going to go ahead an put it in my buddies shop an let him fukkk with it, i also have a rear main seal leakin oil everywhere, so while he's in the i guess im going to go ahead an start moding the motor, probably just cam an pushrods internally for now, then externally probably get headers an a catback exhaust. he says this is the 3rd a4 hes had the same prob on f-bodies within the last 6 months i cant believe this is that common of a problem. so guess its just time to open up the check book, pull out some credit cards, an visit a few atm's......
