Disable adaptive learning with Shift Kit?
Old Nov 19, 2006 | 08:44 PM
2kta--89formula's Avatar
Default Disable adaptive learning with Shift Kit?
I posted in the PCM forum with no luck, maybe someone in here can shed some light?
I heard that if you have a shift kit you should zero out the tables for shift times, is this a must for a shift kit? What ill effects will this have on the tranny?
Thanks!
Old Nov 19, 2006 | 08:55 PM
performabuilt's Avatar
LS1Tech Sponsor
Never heard of that being required and have installed many shift kits and have never seen it in any shift kit instructions so I would say its not required
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
