sorry dumb ?
Old Nov 23, 2006 | 05:45 PM
NiCks Ws6's Avatar
Default sorry dumb ?
tried searching said there is no matches. what is a trans brake? and what is it purpose. once again sorry for the dumb question. i should know this. thanks nick.
Old Nov 23, 2006 | 08:10 PM
Gilbert@Ace Racing's Avatar
Hey Nick,
To begin with... never apologize for not knowing as much as someone else. Nothing at all wrong with that. Everybody had to start somewhere!
A trans brake is an electronically controlled device that applies two opposing elements in an automatic transmission. This allows the driver to bring an engine up to launch / stall rpm's without having to depress the brake pedal. By activating 2 opposing elements... reverse and forward simultaneously... all of the engines energy and all of the torque converters multiplication can be loaded into the transmission until it is time to leave the line, at which time the switch is released and the reverse clutches or band is released and off goes the car.
Hope that helps.
g
Old Nov 26, 2006 | 01:37 AM
performabuilt's Avatar
LS1Tech Sponsor
Like he said its like holding the brakes till the desired RPM then launching but much more efficent
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 26, 2006 | 02:01 AM
NiCks Ws6's Avatar
thanks guys, i had some what of an idea but wasnt sure. can you have a t-brake on a buillt 4l60e?. i take it is alot more effective then holdin the brake and gas at the same time.
