gear install ?'s
Old Nov 24, 2006 | 04:14 AM
gameovergt's Avatar
Default gear install ?'s
I have a 2000 Tran AM A4 with 2.73 gears. I am wanting to put 4.10's in. Which carrier do I have? Where's a good place to purchase gears? Should I get a stronger differential cover? Anyway to make the speedo correct without getting a hand held programmer? Thanks..... I will be getting a stall next summer along with LT's & dual exhaust. I am wanting something to get it off the line a little faster.
Old Nov 24, 2006 | 07:36 AM
DevonsZ's Avatar
You should have a 2series carrier since your car has 2.73's. A better cover is up to you, and with an a-4 you might want to go with 3.73's.
