Car cutting off after converter install
Old Jul 27, 2002 | 04:24 PM
REC's Avatar
REC
Default Car cutting off after converter install
I had a Vig3200 installed a couple of weeks ago. Up till a few days ago everything was fine, but now the car has cut off on me a few times. Sometimes in reverse and when I am just pulling away from a stoplight. Do I need to do an idle relearn? If so how do I do that? Also, my battery gauge runs really low sometimes. It pretty much stays just before the center line and sometimes at night it will drop down to the red line. Is this normal? Thanks in advance
Old Jul 27, 2002 | 08:49 PM
TomQ's Avatar
Default Re: Car cutting off after converter install
same thing happaned to me,
I tried idle re-learn , didn't help, use ls1edit to change the idle or hpp3...
I'm useing 650 in "D" and 850 at "P", I think that's correct... hmm <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
have u also installed underdrive pulley ?
if so, your bettery will run lower(especially if u have subs in your car), it's normal, don't trip here
<small>[ July 27, 2002, 08:50 PM: Message edited by: TomQ ]</small>
