4l60e problems/rebuild....
**Also if you plan on replying to this, you probably would want to read the whole thing and not skim too much b/c i know whenever i read these long ones i always skim through them lol.
OK so ive got the 4l60e which would sometimes over rev and slip a bit from first to second gear. Then it got to the point to where under WOT, it would take a LOOONG time to get from first to second, lots of grinding/friction/vibration througout the shift. Then, the car wouldnt shift out of first gear at all unless i brought the rpms up to about 3500 in first gear and then let off the gas, and it would shift right to third, no second gear at all and no fourth gear either. Stupid me decided to test my luck with the last bit of life in my tranny and laid down some rubber for about 4 seconds until it just let go, tires stopped spinning and the motor reved up. Now ive got no forward gears at all regardless of the shift selector position. I have park, nuetral, and reverse and thats it. And one more thing, one a couple occasions, not very often, i would shift the car out of park into reverse, and the car would NOT move but i could tell the flywheel wasnt quite spinning freely because the car torqued up a little bit when i tapped the gas pedal. Then i got a little more aggressive with the gas and finally it popped into gear but the car wouldnt move unless i hit the gas. Then i put it in nuetral and the car creeped forward. I ran a scanner on it and looked at the data for the transmission, everything appears to be ok as far as the electronics go. After i lost all my forward gears, a few days later i went to move the car and started it and shifted into drive for the hell of it, and it sounded like it ALMOST made it into gear, but didnt. I could tell because of the rpms, say for the sake of a conversation, the rpms drop 400rpm's from when you shift from park or nuetral into a gear, well mine only dropped maybe half the amount of rpm's and didnt go into gear. Car does nothing but sit there and rev up in every forward gear when i try to accelerate. I took out the trans and took off the pan and the fluid looked like death. Dark black with a metallic swirl of metal dust lol.
Now heres my question-
I was told that sometimes a rebuild kit wont solve the problem b/c it could be something else in the trans, such as planetary gears or some other things. Any opinons on WHAT WENT WRONG????? or if a rebuild kit would do the trick? How would i find out what exactly went wrong, so i can maybe narrow down what parts i need to get? And NO i WILL NOT bring it to a professional because i have absolutley no money and cant afford it, and i like sticking my head into things like this anyways its a good learning experience. And no, i wont buy a new one either. Lack of money sucks doesnt it.
OPINIONS ANYONE?!?!?!?
As far as what happened... it really is a mute point right now... bottom line is it has suffered a significant failure and will need to be rebuilt. 4L60e's require special tools... as do most transmissions, it can be done without them, but it adds to the difficulty.
