Converter question?
Old Dec 4, 2006 | 01:11 PM
TN94Z's Avatar
Default Converter question?
With the mods listed, do you think that the 5k stall is too big? Would I be better off going to a 4k or 4400?
1 3/4 flowtech long tubes
asp pulley
t-rex
paitriot gold springs
thunder racing oil pump
ls6 intake
ported stock tb
85 mm delphi mass air
slp lid
dual 3" x pipe with 1 chambers
th350 with rmvb and tbrake
5000 converter
4.10 gears
tuned by horsepower house in bowling green ky.
Old Dec 4, 2006 | 02:12 PM
performabuilt's Avatar
LS1Tech Sponsor
If its a street car I would say 4000 to 4500
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 4, 2006 | 02:14 PM
TN94Z's Avatar
Yeah, I ended up giving Yank a call afterwards and that is basically what they told me too.
Old Dec 4, 2006 | 02:21 PM
LS1Tech Sponsor
answered your PM
__________________
Call 888-744-6542
Old Dec 4, 2006 | 02:25 PM
TN94Z's Avatar
Thanks. I think the converter is going to be the problem with this tranny. The way I understand it is that the tranny has new internals and from what I have heard, this converter is just too much for the HP level and setup of this car.
Old Dec 4, 2006 | 08:06 PM
Ragtop 99's Avatar
It is fairly rare that on an LS1 to see a 5000 stall outperform a 4400. A true 5000 will stall at or above peak torque which is not optimal. You also need to make sure it is an efficent design or it will really eat the HP. Your TRex is probably needs a 7000 rpm shift point, so that helps but a 5000 stall can go higher typically with improved results.
