Converter and trans questons.
Old Dec 11, 2006 | 12:03 AM
LS1T/A4's Avatar
Default Converter and trans questons.
I might be getting a stall soon, I was wondering while the trans is out what upgrades can I do that doesnt require complete dissasembly? I am already planning on adding the Sonnax 2nd and 4th servos, is there anything else?
~J
Old Dec 11, 2006 | 12:26 AM
performabuilt's Avatar
LS1Tech Sponsor
well the transgo HD2 is a good idea
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 11, 2006 | 07:05 AM
PBA's Avatar
PBA
If you are going to install the Trans-Go Performance Shift kit, then you can save your money on not installing the oversize servos. The Shift kit can be modified to firm up 4th gear at all throttle openings, or you can add a stiffer 4th gear accumulator spring and have smooth 3-4 part throttle shifts with firmer shifts at more throttle, and the Corvette/LS1 servo when setup according to the instructions, can give smooth part throttle shifts, along with firm WOT shifts. This is very easy to do and much easier on the wallet. If I can be of help here let me know?
Old Dec 11, 2006 | 01:06 PM
LS1T/A4's Avatar
I'm mostly worried about the 2-3 shift @WOT. I do not race into 4th and I dont plan on it either. Car is a DD, I like the stock settings just want a little crisper.
~J
